How to open this light fixture to replace the bulb?
Old 03-14-21, 03:45 PM
See pictures. Bathroom fixture next to the mirror. I'm not sure how to open the cover to replace the bulb. Any suggestion is much appreciated!
Old 03-14-21, 05:17 PM
Received 517 Upvotes on 422 Posts
There is a phillips screw in the bottom end cap. I would start by removing that.
Old 03-14-21, 05:43 PM
Z
Received 422 Upvotes on 375 Posts
I haven't worked on a fixture quite like that before. But I see a screw at the bottom. I'd imagine removing that will either allow the bottom silver piece to drop out, or the glass screen to pull out to the side. Have you tried starting with that?
-- Sorry Joed, took too long to write my message and posted well after yours. You get all the points if we're right --
Old 03-15-21, 06:55 PM
Hi Joed and Zorfdt! Yes it's the screw at the bottom! Once the screw is removed the bottom metal piece and the plastic cover can both be taken out easily. Thank you both!
