Electrical
Old 04-07-21, 08:49 PM
Electrical
Hi, I put in 7 new outlets, wire for 6 led spot lights(6"), 2 ceiling fans for a new addition of living room. I used 14/2 for all the wiring with a 15amp breaker. One tv will be used as well. Did I use the right wire and breaker for all of this??? Please any feed back will help.
Old 04-07-21, 09:21 PM
Received 513 Upvotes on 418 Posts
14 gauge wire on a 15 amp breaker is the proper setup.
I don't know your location but if you are in Canada you have too many items on the circuit. The limits is 12.
Old 04-07-21, 09:25 PM
Received 3,897 Upvotes on 3,494 Posts
I see you are located in the US so you should be ok. One thing I do is to keep the lighting on it's own separate circuit. This way if the receptacles causes a breaker trip you still have light.
Old 04-08-21, 01:32 AM
I placed one of the outlets 4 feet apart and was told it's supposed to be 6 feet apart and others say it doesn't matter. What do you guys know about this? I'm in the u.s
Old 04-08-21, 05:27 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, you can put them as close as you want, but no space on a wall can be further than 6
Geo🇺🇸
