How to fix seized fan?
Old 04-19-21, 04:26 AM
D
Received 3 Upvotes on 3 Posts
I've got a fan on my porch that won't start. I have replaced the chain switch but that didn't work. I can feel it trying to start but I can't manually spin the blades. What's the best way to unstick the motor or blades?
Old 04-19-21, 04:40 AM
Marq1's Avatar
Received 1,100 Upvotes on 1,000 Posts
If the motor has died the cost of repair will likely be more than a replacement!
Old 04-19-21, 05:55 AM
P
Received 1,759 Upvotes on 1,572 Posts
If you can't turn the fan by hand then it's probably too far gone for repair. If the motor hums and it will start running with a gentle push then oiling the bearings/bushings will often get it going again. But if yours wont turn at all it's probably rusted in place.
Old 04-20-21, 04:02 AM
D
Ok. Are there any recommendations for a porch fan? It's got a long downshaft.
Old 04-20-21, 04:43 AM
P
They are called pedestal fans.
Old 04-21-21, 07:53 PM
D
Received 1 Upvote on 1 Post
If the power is switched off and you cannot spin the fan, it is usually time for a new fan. If you can spin the fan, the capacitor may be bad. You might find the capacitor on line or contact the manufacturer. If replacing the fan, find one that has a short downrod and you may be able to use your existing downrod.
Old 04-22-21, 06:17 AM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
Check and home improvement stores. Most have outdoor fans of various configurations.
