What type of range hood filter bezel is this??
Old 06-22-21, 12:50 PM
D
Hello,
I'm redoing my kitchen and I want to replace my range hood filter and blower.
The filter is in a bezel type case that just slides up into the duct and holds by friction. I believe the filter and bezel are one piece fixed together. I don't think I can just pull the filter out and replace it.
I just don't know what this filter bezel combo is called and can't find a replacement..
The filter is 9 by 13 and the outside of the bezel is 11 by 15.
It just slides up into the ducting which is also 9 by 13.
Anyone know what this setup is called?
Or where should I go for replacement parts for this.
Thanks, lemme know if you have questions.
Old 06-22-21, 01:46 PM
Received 3,986 Upvotes on 3,578 Posts
I don't recognize that unit. A make and model would be helpful.
Replacement filters are available but that entire assembly may not be.
Old 06-22-21, 01:49 PM
P
Received 2,185 Upvotes on 1,955 Posts
There is no standard vent hood filter, most are proprietary by manufacturer and model. I think the manufacturer is the only place you will have a chance of finding a replacement filter or bezel.
Old 06-22-21, 04:10 PM
D
It's a Robin Hood air booster model rh-8
420 cfm inline fan not sure if it's meant to be paired with the filter setup I have or not.
Here's a bad picture of the inline fan.
