Junction Box too big for new light fixture plate! HELP!
Old 06-27-21, 06:23 PM
Okay. So I have only been working on this all day... so I hope my idea passes all electrical guidelines. In order to feel Okay with everything I need a second opinion before I just try and attach everything. Which I am still working out in my head. So the junction box is huge compared to my new Hampton Bay 3-Light Track Fixture. It was an oh so over used "boob" light which explains the large junction box I guess?
I figured if I cut a piece of wood in a circle to cover the junction box and then cut a smaller hole out of that to fit the fixture plate that'd be fine, right? I'll add pictures so you won't have to guess at my crazy plan. I am no electrician to say the least. Picture 1: my crazy plan of a wood circle to attach to junction box opening (with new fixture plate attached). Picture 2: Junction box.
If that is all fine and dandy (the junction box opening being closed with mostly wood). Then my next problem is this. All I was thinking about was closing this hole. Not attaching it later. I know... way to go me! But I have these really long screws (pic 3) that I could maybe drill into these little slit openings (pic 4) in the junction box? Or is that a no go? Or I have this metal bracket thing (pic 5) that came off the other light. Maybe I could cut it in half and use it on either side of my wood piece to attach it... then I'd have to spackle over it all and it'd look ridiculous. I don't know what to do! Help!
And as if that wasn't enough... the old light had this metal curly spring thing (pic 6) attached to the junction box which was attached to the ground of the old fixture. It kinda just came out with the fixture so it wasn't really doing a whole lot of good anyways. Am I good just attaching the new fixture ground to the screw on the metal plate and not to the junction box? Even if the metal plate isn't making contact with the junction box because of my crazy wood circle plan?
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
Picture 6
I feel like I've wasted an entire day. Please give me good news...
Old 06-27-21, 07:04 PM
Received 477 Upvotes on 393 Posts
That is not a junction box. It is a pot light fixture. You cannot use it as a junction box. You need to remove it, patch the hole and install a proper junction box.
Old 06-27-21, 07:26 PM
Received 3,414 Upvotes on 3,063 Posts
Welcome to the forums.
As mentioned..... that's an actual light fixture.
That spring is one of two or three used to hold the trim up to the ceiling.
In the picture..... remove the three or four 1/4" hex head screws. You can use a short screwdriver or socket set. After the screws are removed..... push the can up into the ceiling. You'll now see a junction box. You need to make sure the cable in the junction box is long enough to be removed and connected to a new box that you'll install.
Old 06-27-21, 07:33 PM
Okay so I haven't found the junction box at all then?! Wow and I thought I was doing a not great but atleast an alright job. Should there have even been a boob light installed over this in the first place?? Wouldn't be the first crazy thing I've found in this house so far.
Old 06-27-21, 07:34 PM
This is what is in the ceiling. The frame is nailed in between ceiling joists as shown with the brown lines. When you remove the screws the center cover (red arrow) will push up and out of the frame. You'll be able to see the junction box where the blue circle is. That's what you have to get to. Much easier to work from the attic if you have one.
Old 06-27-21, 07:46 PM
I do have an attic. Much rather not go up there but hey I've come this far right!? So I'll go up there and remove it (got the ancient screws out) and connect my new fixture to the actual junction box. Is my wood circle piece a bad idea? If I'm going in the attic I can attach it from up there much easier anyways. Glass half full
Old 06-27-21, 07:49 PM
If you go up to the attic you can remove the entire fixture.
Take the wire out of the junction box. It will go to your new junction box.
Old 06-28-21, 05:55 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, looks like there will be some ceiling repair, while your in the attic find a rafter that is close to the location for the new fixture or use a bar box with a 4” round box in the center of that opening and patch around it, then install your new fixture, not as hard as it sounds.
https://www.acehardware.com/departme.../boxes/3550548
Geo 🇺🇸
Old 06-28-21, 11:39 AM
So would that piece from ace be replacing the entire junction box? Or just be attached to it and be the piece seen from the bathroom ceiling?
Old 06-28-21, 11:48 AM
Geochurchi's Avatar
Hi, you would completely remove what is there and and install the new box in the center of the old hole, bring the wire from the old fixture directly into the new box, you will obviously have to patch the old, there are several ways to do that, I might patch the hole first.
post a pic of what the area looks like in the attic.
Geo🇺🇸
Old 06-30-21, 10:13 AM
Z
Received 363 Upvotes on 325 Posts
Conversion kits do exist for pendant type lights.
https://www.amazon.com/Westinghouse-.../dp/B00FGQ19LC
