how to remove my ceiling fan
Old 07-06-21, 05:56 PM
L
I have this ceiling fan I want to replace. I was painting the ceiling and didn't cover it. it has some paint.
from reading youtube, it seems that ceiling should have a decorate cover that you can easily remove it.
but I when I use screw driver to pry mine, it doesn't come off easily. I don't see any screws around either.
any tips on how to remove this ceiling fan?
Old 07-06-21, 06:19 PM
Received 3,880 Upvotes on 3,477 Posts
That looks like a Hampton Bay canopy.
Pry that ring down/off where the red arrow is.
There should be two screws under it that will release the canopy.
Old 07-06-21, 07:53 PM
L
Thank you so much PJmax . I'm glad I didn't pry too hard from top and would have damaged everything.
even after I pried off the bottom ring, I don't see screws. please see this image
Old 07-06-21, 08:45 PM
Hmmmm..... then the trim ring at the very top of the canopy turns.
You may have to cut the paint between the canopy and the ceiling.
A possible helpful video
Old 07-11-21, 05:23 AM
L
Just an update. It is the top ring. I had to pry a bit harder to detach it.
