Do light+fan combos use the same wires as ceiling light only units?
I would like to replace some ceiling lights with light+fan combos - the type with the strings to turn on fan and light.
Do the fan combo lights require anything beyond a normal light fixture in terms of wiring or other considerations, or will I be able to simple swap using the same wiring?
You will need fan rated boxes in the ceiling to support the extra weight and movement of a fan. Most fans can use the same wiring as a light so no difficulty there.
Most newer fans will have an electronic module and remote that will allow just one 120v set of power lines to run the fan and lights separately.
