Switch to nowhere
Old 08-06-21, 12:23 PM
Switch to nowhere
I have a two switch panel and one switch goes nowhere. The other switch turns on two lights. I'd like to make one switch go to each light Independently. That's not an issue. But the dead switch has wires connected. A red (that gets no power), a white, and a ground. From the same main wire, though, is a capped black wire (hot). I tested them all.
Is this safe? I have no idea what else the cable is connected to.... nothing? Can I safely disconnect and cap the red and white and use the switch?
Thanks, Jeffrey
Old 08-06-21, 03:42 PM
Received 477 Upvotes on 393 Posts
Should not be a problem to cap the two wires.
Old 08-06-21, 07:12 PM
Received 3,420 Upvotes on 3,066 Posts
Welcome to the forums.
I took the liberty of clarifying your picture.
We see three cables.
Cable A is power in to left switch. Cable B is switched power out from the left switch.
(could be reversed. can't tell from picture)
Cable C is a three wire cable. You said black is hot. The switch does nothing. Sure you could take the red and white wires off the switch and cap them off like the black wire.... but what then ?
Since you have only one cable out to the lights (A or B)..... the lights are combined at the first light. You'd need to get a wire from that light to the switch box in order to use both switches. That is not as easy as it appears.
Old 08-06-21, 08:55 PM
Pjmax
I assumed cable A went to one light and cable B to the other. Is that a poor assumption?
Also, you say what then about capping the red and white. But if But have no power and the switch effects nothing, is there any reason to have them attached to a switch? That's a legitimate question, btw. There may be a reason but I don't know enough to know what that could be.
Thanks
Old 08-06-21, 08:58 PM
Yes.... sorry.
Based on the left switch wiring.... one cable is the power and the other goes to the light(s).
Old 08-07-21, 09:43 AM
Yep. That makes all the sense. Not really sure what I was thinking but feel a bit dumb now. So it goes. And thanks again for the help.
Old 08-07-21, 11:07 AM
Don't feel dumb. You asked first. If you did the work.... then you'd have a reason to feel dumb.
