IKEA ceiling light repair
Old 08-17-21, 11:13 AM
I have a ceiling light I bought from ikea about 10 years ago. It is no longer available at ikea. I was changing the bulbs and one of the light ceramic insulators was damaged and fell out. Obviously it will short out of the switch is turned on. I,m trying to figure out a way to repair this. Could I just fill the hole with epoxy to insulate it?
Old 08-17-21, 11:56 AM
P
Received 2,009 Upvotes on 1,801 Posts
No, epoxy will not withstand the intense heat. You need a ceramic lamp base. If you remove the base so you can get a look at it you can search online for something that might work.
Old 08-17-21, 01:48 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Well, maybe, if you switch over to LED bulbs your repair may work, they are much lower in heat than any other bulb!
Old 08-17-21, 06:05 PM
Received 77 Upvotes on 72 Posts
As much as I hate that word this is a valid use case in my opinion.
