Connecting pink wire
Old 08-25-21, 05:55 PM
P
Iím replacing a light fixture on the exterior of our garage wall. Coming from the wall there are 3 wires: black, white and pink (no bare copper). In the new light fixture there are: black, white and green. Iíve seen on many forums that pink wires are common where a ceiling fan once existed but thatís not the case here (external wall). I assume I connected black-black, white to white, and screw green to the box Ö but what to do with the pink?
Old 08-26-21, 03:11 AM
Received 516 Upvotes on 421 Posts
How was the old fixture connected?
Old 08-26-21, 04:26 AM
P
Received 2,180 Upvotes on 1,950 Posts
Is this a three way circuit (two switches control the light)?
Old 08-26-21, 08:49 AM
P
unfortunately the carpentry contractor removed the old fixture, so I didn't see how it was wired before
Old 08-26-21, 08:51 AM
P
Its an old garage so may have had two switches originally, but not currently. It is one of 2x lights (either side of the garage door), but both are controlled by one switch now.
Old 08-26-21, 10:09 AM
I would try white and red. If that doesn't work then try white and black.
One setup will probably work with the switch and the other probably will be always on.
Old 08-26-21, 10:10 AM
Received 3,980 Upvotes on 3,572 Posts
You may have had old three wire cable with no ground. That would be fairly old.
Connect the light.... white to white, black to black, cap off the red/pink wire, don't connect green.
See if that works.
If the light won't shut off..... move the black light wire to red/pink and cap off black in box.
