Recently wanted to replace an old outdoor flood light with a more modern fixture. When I removed the flood light, the wiring was as follows: 2 whites together, grounds together, one black with marrett and one black going to the flood light. (see photo). The new fixture has three wires: one black, one white, one ground. I connected each of the black from the junction box to the black and white of the new fixture, also connected the grounds. I got power, but the light did not work. I reversed the black and white from the junction box to the new fixture, same result. What can I do to get this right. There were never issues with the old flood light. Original set up with old flood light. Kept the 2 whites together New junction box with black separated for hook up to new fixture. Switch set up #1 2 black wires on left switch, one black on right switch to outdoor light Right switch to outdoor light feeds off switch on left
You are switching black (hot) at the switch and the white wire is spliced to neutral. That means at your light..... only one cable will be switched and used. You need to locate which cable (white and black) becomes live with the switch on. The other cable gets capped off.
Thank you for your help, I found the live black and white and capped off the other black and white. Connected the fixture and it works the way it should. Thanks again.
We're adding the finishing touches to our kitchen remodel. We've purchased some low voltage pucks, that tie into a main low voltage cable, which connects to a dimmable LED power source, & finally an AC dimmer. A wire runs out of the back of the puck & ties into the main low voltage cable. With low voltage landscape lights, a connector ties you into the main line. Does any type connector exist for our puck lights?
Have a Hunter Bay ceiling fan, about 12 years old, been running fine up until a week ago or so. Fan and light stopped working. I checked the breaker, it's fine there. Checked the power going to the wall switch, fine. Checked the power going to the light bulb socket and there's power going to it - so I can imagine if the motor or the capacitor burned out, that it would stop the fan, however how can a light socket getting power not illuminate a bulb? Changed light bulbs, neither work, same one from fan works in another table lamp. Please advise if you have any clue or if I'm missing something, thank you.
