Help installing wireless 3 gang light switch
Old 09-17-21, 07:56 AM
H
Question Help installing wireless 3 gang light switch
Hi everyone, I'm trying to convert my standard 3-gang light switch into a wireless one. However, I'm a bit confused about how the wiring should be connected to the new switch.
In the attached photo, I believe there are 3 wires (#2,3,4) which are connected each of the 3 lights. I think wire #1 is the mains power, but I'm not sure what the 2 red loop wires are (Active or Neutral?)
For the connection, I've tried connecting:
#1 to A
#2 to A1
#3 to A2
#4 to A3
However, this doesn't seem to work and I'm not sure how to connect the neutral (N) terminal...
Any help would be greatly appreciated! Thanks
Old 09-17-21, 11:10 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums from Australia.
This is primarily a North American based site. Our wiring is different than yours.
I'd recommend finding some local help there for you wiring issue.
Old 09-17-21, 05:20 PM
I stopped back to look over this thread. I labeled where your four wires go.
1-3 are the switched hots out to your lights.
4 is the always live hot in.
You do not have neutral in that picture. That's what you need.
Old 09-18-21, 05:09 PM
H
Thanks @pjmax! You guys have been very helpful!
I'm a bit confused about the lack of a neutral wire in the existing switch, how can it work without a neutral wire? Do i need to tap into another neutral nearby?
Old 09-18-21, 09:19 PM
H
Problem solved! I managed to tap into a neutral wire in the socket next to the switch and voila!
Old 09-18-21, 09:31 PM
The switches themselves don't require a neutral to turn the light on and off.
Your wireless control is what needed the neutral to operate the wireless receiver.
