I have a two-story house that was built in the 80's and sits on a concrete slab thus no basement. I want to put a washing machine in my utility room. However, the rooms does not have a drain. Since the house is on a slab it seems my only alternative is to pump the water up 8ft and exit through the utility room to the garage. Then from there tie into a drain that's in my half-bath area.
The image below highlights what I'm planning to do.
Does this seems reasonable? Can I tap into that vent pipe that I exposed in the garage?
I'm not sure if this is to code. I appreciate any recommendations or alternate ideas for this project.
I would run the pipe under the doorway to a pump below the wall opening rather than up and over. Others will chime in about tying into existing pipe i'm sure.
Pretty sure that the minimum drain size for a washing machine drain is 2" now, and many vents are 1 1/4". Also pretty sure you have to consider the number of drains vented through that pipe and their sizes to determine the minimum size. Not a plumber, but I'll bet the answer will be no.
I am wondering if you can run the 2" washer drain below the doorway, and just build a little wooden step/platform to cover it. Then tie it into the drain.
Can you confirm whether the sink drain is 1.5" or 2" where it goes into the slab? As ThisOldMan stated, washers require a 2" drain.
Otherwise I think a pump and drain like you have it drawn would be okay. Check the output size of the pump, most are 1" as far as I know. You'll also need an atmospheric vent (one that goes up to the roof) for the pump, an AAV won't work.
When I turn on one of our ceiling fans, I immediately get a steady, low-level humming noise. It reminds me to some degree of the humming sound associated with older flourescent bulbs. When I Googled the issue, I found lots of comments about loose screws, loose blades or issues with remote controls, but I don't think so. The fan is on a light switch, with no remote. The sounds begins immediately when I turn it on - before any blade movement, and stops immediately when I turn it off, before the blade rotation begins to slow. I'd guess the fan is about 20 years old. Any suggestions are appreciated. Thanks.
I have a 3 light fixture over my bathroom mirror. The one on the left goes on and off. An electrician looked at it and said I needed a new fixture but didn't have time to fix it and hasn't responded to calls since. How hard is it to fix myself? Please see photo.
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/light_992dadbf374d64196f26410c8a398a4b25583fba.jpg[/img]
