I am trying to add couple of lights to this wall that plug is there.On the picture the plug has one black side empty and white side the same.
Can use these to add the wire to a switch and from there to lights?
Yes you can.
But I see wires using the pushin back stab connection. Those tend to fail. I would pigtail all the black and connect using a pigtail to the receptacle. Same thing for the whites.
Yes you can.
Using the push-in terminals for in and out use is asking for trouble. You will have problems in the future if the wires are left that way. If your house is wired that way you'll have something to look forward to in the future.
I have hundreds of condos wired that way that I work in.
It's never a dull moment.
Can I use a 5 or 6 ft long wire as pigtail for this switch?
I am using Lutron C-L dimmer switch and with 3 wires (2 lights and one from the receptacle) for the switch box ,it makes too crowded.
In that case,Can I connect the 2 lights wires together with wirenuts (I really like those 3ms wirenuts) ,putting them in the metal box on the wall and just take a wire from there and one from the receptacle to the switch for the lights?
Reason: I was not making sense
How did switch come into this? If you are wanting to add a switch then you need to run a cable from this box to the switch box. All connections must be made in a junction box that is accessible. You can't bury any connections inside the wall.
I got you the picture ,the red will be lights locations and blue is the metal junction box that I was going to put inside of wall to the stud and yellow is the receptacle.I was going take a wire from receptacle to switch box(to turn it on and off in the back of the wall in other room on the wall) take a wire from each light and using wirenuts together in that blue color shows the metal box and from there connect the black wire from lights to red on the dimmer and black from receptacle to black on that (Lutron C-L) dimmer and cover up everything.I hope I am not confusing you more.
So you're going from the receptacle to the blue junction to each light.
The dimmer is in the blue box ?
OR....
You're going from the receptacle to a switch box with dimmer to the blue splice box and then to both lights ?
All the whites will go together. Black from the receptacle goes to black of the dimmer. Red from the dimmer goes to the two black wires of the lights.
I didn't realize you were going to bury the splice box.
Are you putting in boxes for the lights ?
All splices must be contained within an electrical box.
Based on that you could bring the wire to one of the lights and then jump to the other one.
I am doing like you said ,All the whites will go together. Black from the receptacle goes to black of the dimmer. Red from the dimmer goes to the two black wires of the lights.But it gets to crowded and dimmer has big box on the back.I was asking ,can I put 2 blacks from lights together with wirenuts and whits(and put them in the metal box) and add single wire from there to red on dimmer with black from receptacle to black and leave the white alone in the dimmer box?
So ,I will have enough room in there.
So I do it reverse,receptacle black to dimmer from red on dimmer to first light and from there to second.Or from red to blue metal box and from there to both lights.
When you do wiring..... you use cable. So you'd need a two wire cable w/ground from the receptacle to the switchbox. Then a two wire cable w/g from the switchbox to one light. Then a two wire cable w/g from one light to the other. You can't just have one wire.... like white or black. Does this make sense ?
Using a deep electrical box you should easily get two cables in the box with the dimmer.
Yes it does I forgot to mention the black and ground.I will use deeper box(If iI can find one,all the boxes are gone in my area mostly metal one).Thanks a million.I finish it tomorrow.
I am replacing a three way switch with a smart three way switch. The new switch has a line, 2 travellers, ground and white cable. The three way switch I am replacing has a hot or line connected to the black screw and a red and black travellers. This is what is expected and I have changed a few of them. THERE IS HOWEVER ANOTHER BLACK JUMPER WIRE DIRECTLY CONNECTING THE BLACK LINE SCREW TO ONE OF THE TRAVELLERS (the one on the same side of the switch). I connected the smart switch as it should be connected but when I turn it on the light blinks and then goes out. If however I add the jumper between the line and one on the travellers the switch works perfectly. Everything works. I am pretty good with electricity but can not for the life of me figure this one out.
BTW - the other switch in this circuit is an old Intermatic timer switch that has three black leads (hot and two travellers I assume)
Thanks for any help.
[color=#383a3b]I have six recessed lights in my kitchen ceiling. About a week or so ago, I noticed that when I first turn them on in the morning (or after they have been off for a while) they all flicker rapidly, and then after 30 secs or so they flicker more slowly, and then eventually it stops and they work fine. Almost like they flicker until they warm up. Nothing has changed from an electrical standpoint in the house, this just started out of the blue. No other lights in the house have this problem. Also, these are just standard lights, not LEDs. Thoughts?[/color]
