I have an old 4 bulb 4’ fluorescent light fixture in a nice wood frame that I’m looking to replace with LED. Do any of the new LED lights have replaceable bulbs? The ones I’m seeing are called “maintenance free” so they can’t be repaired but just be replaced. I haven’t had the best luck with LED lights, I know they are purported to last a long time but I’ve had quite a few fail prematurely.
You can be creative. You can use different color temperature tubes. In my kitchen I have a four tube 4' fixture. I use two 4100k cool white tubes and two 6000k daylight tubes. The lighting is very natural. Bright but natural.
Over my bench I have the same thing but I added a pull chain so that it's two or four tubes lit. Normally only two tubes are needed.
I see some bulbs that are supposed to work with a ballast as opposed to going direct wire. It appears that direct wire bulbs are significantly more expensive. The fixture is probably 20 years old, may have a bad ballast anyway. I’m assuming you are all referring to the direct wire type bulbs where the ballast is bypassed.
Bypassing the ballast is the best way to go. If you do the plug and play you will still be relying on the ballasts to power the lamps which can also fail. There also may be compatibility issues between plug and play lamps and the existing ballast.
Thanks for the links, I missed these when I looked on their web site. I plan to removed the ballasts and direct wire. I’ll let y’all know how it comes out. Thanks for all of the help!!!
Thanks for all of the input. Worked great! I had intended to use the existing original sockets but noted info in the instructions related to “Shunted sockets” for fixtures with rapid start capability. Both ballasts indicated rapid start so we swapped the 4 “feed sockets” with the new ones provided. Since LED bulbs are only fed from one end we just snipped the wires on the tail end and taped them off. LED bulbs MUST be installed properly so that the proper end of the bulb is on the “feed end”. Stickers were provided to inform of this important polarity. It was very bright so we will probably add a dimmer in the future.
Hi I replaced my round ceiling LED light after my previous light stopped working after a couple of years. The previous light was working perfectly fine. Now every time I turn this new light on it just keeps blinking rapidly. The light switch is a standard on/off switch.
any advice appreciated.
Thanks
I’m adding a vent fan to a bathroom and need to get the extra wire from a wall mounted switch box up to the attic. Any special tricks for this? The existing romex goes in a hole in the top of the header and down to an existing original metal box nailed to a stud. Should I hit out the old box and replace with plastic? Drill a second hole in the header next to the original one? Just wondering if anyone has any tricks or techniques to make this easier….
TexasFire
