Hello, I'm designing some lamps using standard bulbs and want to mount the socket right into a wooden base, as in the photos. My lighting supplier has many different types of sockets. Which type is recommended? Thanks for reading.
Sockets & bulbs get hot & depend on free air to limit their max temperature & so extend their service lifetime.
Wood is somewhat of a thermal insulator. With a high wattage bulb you may get charring of the wood.
It's in your favor that the bulb is above the socket.
With that second pic, I'd drill small horizontal holes at the socket height to allow air to enter, keeping the bulb & socket cooler.
Best would be to have free air circulate around the socket by having the socket hole 1/8" larger in diameter than the socket exterior diameter.
"My lighting supplier has many different types of sockets. Which type is recommended?"
Much of that depends on you and the tools you have available. High on the list would be ease of installation. Which sockets can YOU successfully mount?
Also, do not forget some sort of power cord strain relief. If someone pulls on the cord you don't want the connection to the socket to be the only thing holding the cord in place. Usually there is a knot or strain relief of some type before the cord exits the fixture.
I'm planning to run some led under cabinet lights in my kitchen. However, all the sets I find on Amazon all come with remotes and can only be turned on with the switch or remote that comes with the set. I'd to control them with a powered outlet or switch. But none of them seem to work like that. From the reviews, it looks like if you hook them up like that, all that does is supply them power, not actually turn the lights on. You still have to turn them on with the supplied switch or remote.
Does anyone know of a set that I could power on with a regular switch or powered outlet? Or a way to modify the others to do that? I'd 0refer the strip lights, not the ones in the plastic housings, as they are too bulky for my liking. Thanks! Read More
After replacing all my track light heads, none of the lights power on. Prior to installing the last one all others were working. What would cause this and how to fix? This is an H style track. I have checked the breaker box twice and reset it anyway. If the last head is bad that would not cause all others to go out, right?
Thanks!Read More
