Changing a 3 way lamp to a 1 one lamp?
Old 02-05-22, 05:34 AM
T
Received 3 Upvotes on 3 Posts
Hi I have a three way Pedestal Lamp and I want to change it to just a on and off switch(one way). Do I have to change the whole wiring or can I just buy a One Way Switch? Thanks
Old 02-05-22, 05:39 AM
P
Received 1,768 Upvotes on 1,581 Posts
Just replace the switch.
CircuitBreaker voted this post useful.
Old 02-05-22, 06:03 AM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
You could also just install a standard light bulb. It just might not work in some positions of the 3 position switch.
Old 02-05-22, 06:08 AM
T
I already have a one way bulb in it but don't want the hassle of moving it three time.
I think I will go with Pilot Dane's suggestion and just buy a one way on/off switch,
Old 02-05-22, 06:47 AM
Received 477 Upvotes on 393 Posts
If I understand correctly you need a new one way socket since the switches are built into the sockets.
Old 02-05-22, 01:33 PM
T
Thanks Guys I will buy a one way socket next week and put it in, Thanks again
Old 02-06-22, 08:20 AM
T
Ok Guys I was able to get a one way socket today and put it in the 3 way lamp. it was successful, Thanks guys. NOW I HAVE ANOTHER QUESTION.
I also have a one way table lamp in the living room, so i bought a 3 way switch. Will this change it to a three way or do i also have to have a 3way bulb?
Old 02-06-22, 10:34 AM
You have to use a 3-way bulb otherwise it will work like the other lamp with a 3-way switch and a standard bulb. 3-way bulbs have two sets of circuits in them. The low setting and the middle setting. Put them together and you get the high setting.
Old 02-06-22, 10:55 AM
T
Tolyn Ironhand That's what i was afraid of, so I might take the three way switch back, because the three way bulbs are a little expensive and they don't work very long, at least my friends did not. So i found this Dimmer switch and I put that on the one way lamp and it works great. Don't need a three way anymore, Thanks
