Transformer question
Old 02-07-22, 04:48 AM
So we have a track lighting system in our kitchen on a single pole dimmer that has worked fine for years, although I've noticed the transformer has gotten quite hot at times. Yesterday, I replaced the dimmer with a smart dimmer which worked fine for about 6 hours. I believe the transformer has burnt out because it got hot again and there's an order coming from it. Since the smart dimmer is connected to the name neutral as the transformer, could it be what caused it to burn out? Do I just need to get a dimmer with more wattage?
Old 02-07-22, 09:45 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
When there is a transformer involved you need to use an electronic ballast that is approved for CFL/LED use. It wouldn't have anything to do with a neutral on the dimmer.
Old 02-07-22, 10:44 AM
Thanks Pete. Both the transformer and dimmer are CFL/LED compatible. Do you think there is a difference when using a magnetic or electronic transformer? I'll need to get a replacement, so I don't want to burn up another one.
Old 02-07-22, 01:38 PM
It's getting harder to find replacement transformers. Almost everything today is switching supplies.
Most of them seem to dim ok.
What are the specs on your requirements ?
Old 02-07-22, 02:07 PM
Thanks again Pete.
The lighting vendor recommended two from a company called Encompass Lighting Group. The original transformer is from the same place. The models they recommended are:
700AT152EL : Electronic transformer LED compatible.
700AT150T : Magnetic transformer LED compatible.
They're both 12V and 150W but kind of expensive, so I only want to buy one once. I'm not sure magnetic or electronic makes a difference.
I realized that I should also mention that this is an older light system that uses halogen lights - if that makes a difference. Like I said originally, it worked fine on a dimmer for 12 years.
Old 02-08-22, 04:47 AM
B
Received 235 Upvotes on 208 Posts
If all you did was change out the dimmer with a compatible dimmer power and voltage wise, the power supply is not affected. How did you select the new dimmer?
Old 02-08-22, 06:14 AM
I used an Wemo smart dimmer because I've used their product in other parts of the house. The voltage and wattage specs are the same as the old Lutron dimmer that was there. It was only after the transformer went that I've learned about magnetic vs. electronic transformers/dimmers and leading edge vs trailing edge dimmers. I'm not sure if any of that makes a difference or if the transformer just wore out. I misspoke earlier, it's actually 15 years old.
Old 02-08-22, 11:22 AM
Magnetic is an actual 120v to 12v transformer.
Electronic is a switching supply. No big transformer.
It's getting harder to find actual large current transformers so I can understand the price on the T model.
Switching supplies are usually much less than actual transformers.
For example - 150w driver
Is this for a monorail system ?
Halogen bulbs ?
Old 02-08-22, 01:42 PM
Thanks again, Pete.
Yes its monorail system with halogen bulbs.
Old 02-09-22, 05:26 AM
B
Unless Wemo and Lutron make the same dimmer, your new dimmer is different than the old. Using a Wemo dimmer in other parts of the house is of little significance since that load is different than the load your new dimmer is connected to.
Old 02-09-22, 06:39 AM
Understood Pete. Thanks for this, it was very helpful. This is the only place I've used the Wemo dimmer on a transformer. I think I have to come up with a new plan.
