Light installation wiring help
Old 02-13-22, 07:22 PM
Hello, I have a light fixture I am trying to install in my kitchen. Previously there was a ceiling fan there. When I opened the ceiling electrical box, I found 2 black, 2 white, and 2 ground wires. Each was connected to its respective color. My light fixture only has 1 black 1 white and 1 ground wire. Can I just connect the light fixture wires to the respective wires in the electrical box? I would end up with 3 of each color knutted together. The old ceiling fan was connected to a light switch that would activate the ceiling fan light and another light fixture in the room. The actual fan would need to be activated by pulling on a chain. The blue and black ceiling fan wires were connected to the black wires in the electrical box, white to white, green to ground. I don't want to burn my house down... Thanks!
2 wires of each kind
old fan wiring. Fan white went to ceiling 2 ceiling whites. Fan Green went to 2 ceiling grounds. Fan black and blue went to 2 ceiling blacks.
Old 02-13-22, 07:31 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Connect your new light to the black, white and ground splices.
Now when you turn the switch on..... both lights will come on together.
