Extractor Fan / Wiring
Old 04-20-22, 11:12 AM
I
Hello!
Trying to change all extractor fan to a new one. UK based Flat.
Old fan was connected to 4 wires:
​​​​​​2 Red1 black1 yellow-green
New extractor fan has only 3 connections:
L - Permanent Live
N - NeutralLs - Switched live
How should I connect them and what should I do with the 4th wire?
Thank you!
Old 04-20-22, 11:41 AM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
You should have three connections..... switched hot/live 230v, neutral and ground.
Your old fan may have been two speed. That would explain the fourth wire.
You would need a meter or tester to check and see which of the four wires is high and low.
