Hi, does anyone know how to remove this bulb, it does not have a ring around it to pull it up and out, maybe it’s not meant to be replaced, part of the string is out,
Geo🇺🇸
After finding instructions buried in a bag, it said there are replaceable and non replaceable bulbs, the ones with the white rings are of course non replaceable, I figured something like that as 1/2 the string is out.
Geo🇺🇸
Hi, I am replacing a light with ceiling fan in one of my bedrooms. After I installed the ceiling fan, the fan and the lights of the fan turns on. But my other lights (light at hallway and light above staircase) are all not working. Those lights were controlled by the same circuit switch as the ceiling fan. I thought I might have some loosened connections. But I uninstalled the fan and I didn’t find any loosened connection. So I am not sure if my wiring is correct. I have attached one photo I took when I removed the original light. And the 2nd one is the wiring I am using for the ceiling fan. Am I missing anything? Thanks in advance.
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1479x1125/c2428294_bb7c_47ac_b3ed_6072f420fa1d_fcf7ce454e456f9b6678f0c92c59607d5edb2f9c.jpeg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1475x1125/67892002_5cec_42a6_80c8_f94c32b9559b_c6eea255359e079fdec30e32a613bf59ffb2bfd4.jpeg[/img]
I installed a Patriot ceiling fan Model No. 355-0703 and when I remove the transmitter for the remote the light turns on and the fan turns by just flipping the single wall switch. When I install the transmitter, there is no power at all to the light or the fan, nothing works at all. I've checked the connections, batteries, DIP settings...do I need a special kind of wall switch or is there something I'm missing? Any help would be appreciated greatly. I can leave the transmitter out, but there are no chains on this fan so it's either fan and lights on or fan and lights off.
