Removing bathroom ceiling lights
Old 06-02-22, 05:14 PM
O
Received 2 Upvotes on 2 Posts
Have the pictured ceiling light above my showers and baths but can't figure out how to remove them. Any ideas short of breaking them? The trim appears to be caulked to the surrounding ceiling and the glazed cover turns but doesn't appear to unscrew.
Thanks!
Old 06-03-22, 05:11 AM
Received 477 Upvotes on 393 Posts
The trim probably pulls down after you cut the caulk away. It should not have been caulked..
Old 06-03-22, 04:57 PM
Received 3,421 Upvotes on 3,067 Posts
Although the trim isn't supposed to be siliconed in place it's a fairly common occurrence.
You'll need to score the silicone with a knife and you may need a spackle knife to pry the trim off the ceiling.
Old 06-04-22, 09:12 AM
O
Ok will try that.
Do they sell these models anymore?
Old 06-04-22, 01:06 PM
That looks like a 5" trim. Several companies offer replacements. That may be a Halo fixture. They were the most popular recessed fixtures sold. You have a two piece trim. The ring and center piece fit together to form the trim.
You could consider switching over to an LED retrofit trim. All one piece. They come in 4", 5" and 6" sizes. Get one with multi colors and you can choose the color of the light that's most pleasing.
Many sizes and light/color available.
Old 06-06-22, 07:33 AM
O
You're right; I changed the bulb and it's turning on now as you can see.
Is there an easy way to fix the drywall damage though? I really hope I don't have to go through texturing and painting all over again.
Old 06-06-22, 08:30 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
I agree with Pete, replace that trim with an LED retrofit kit, you値l be happy you did, there shouldn稚 be very much patching to do, a little Spackle should do it.
Geo🇺🇸
Old 06-07-22, 11:48 AM
The really isn't any drywall repair. The damage looks to be in the coating.
You can get a premixed spackle to repair that.
Use a drywall knife to apply a thin coat on the area.
You can use a sponge to tamp the area as it drys to give it a textured look.
Old 06-07-22, 11:59 AM
O
I will try that. I actually just purchased 26 of these but am worried that the trim won't cover the damaged drywall, and I hate repairing drywall:
https://www.homedepot.com/p/Juno-Con...I-M6/315133844
Old 06-07-22, 03:16 PM
Those show as an inch bigger all around.
