Ceiling Fan with no unswitched power
Old 06-14-22, 08:57 AM
G
Received 2 Upvotes on 2 Posts
Hi All,
I couldn't find a post about this so I'm going to ask, even though I think I know what the answer is.
I want to put a ceiling fan (no light) at the top of the stairs using the existing box. The circuit has two lights, two 3way switches, and one 4way switch.
If I install with the wiring "as is" I will have to turn on the switch to run the fan. But that will also turn on the remaining light. That is not acceptable.
Is there a way to wire it so I can run the fan without the other light?
Old 06-14-22, 01:00 PM
Received 3,415 Upvotes on 3,063 Posts
You want to replace one of two hallways lights with a fan.
Don't you need a light where the fan is going ?
It doesn't matter how the circuit is switched.... it's where the power enters the circuit.
You'd have to drop that light and see what is in the box.
The chances are not good you'll find always live power there.
Old 06-14-22, 01:08 PM
G
I don't need a light there, at least not now.
And I already know that there is no unswitched power in that fixture, that's what I'm saying.
Any "Electric Man" secret wiring magic?
I'm thinking my only option is to pigtail it to an outlet.
Old 06-14-22, 01:10 PM
Sorry...no secret magic solution.
Old 06-14-22, 01:13 PM
G
Rats!
lol
Thanks though.
Old 06-15-22, 09:54 AM
Z
Received 364 Upvotes on 326 Posts
I do have a bit of a magic solution!
You can use remote controlled switches, or some type of simple home automation devices. Basically the lines remain always on, and you use the remote switches with the control box in the fan/light box to control the fan and light separately.
Here's an example. I'm not a huge fan of this one since it's an off-brand, likely with no UL listing.
https://www.amazon.com/Wireless-Rece.../dp/B09NC2837Y
They have similar remotes available for fan control too.
I would have thought that Lutron would have something in there Casseta line that would work, but I haven't been able to find one.
Also, slightly related, you'll most likely need to change out the box. Most ceiling boxes installed in hallways are not fan-rated and can easily work free and fall when hanging a heavy fan that moves.
Old 06-15-22, 10:46 AM
G
Interesting, I will look into this.
Thank you!
Old 06-15-22, 12:05 PM
Marq1's Avatar
Received 1,099 Upvotes on 999 Posts
And don't forget if you do put a fan there it needs the proper box for support!
CircuitBreaker voted this post useful.
Old 06-15-22, 12:49 PM
G
Yupp.
