Thermostat Wiring
Old 06-21-22, 08:23 PM
D
Thermostat Wiring
I have an attic exhaust fan thermostat and I was wondering if I could wire it to a receptacle to control a plug-in fan. I would like for it to come on and off when it is set to a certain temperature. This will be used in a small outside building.
Old 06-24-22, 10:17 AM
Z
Received 364 Upvotes on 326 Posts
No issue with wiring the thermostatic switch to a receptacle. Some attic fans are wired like that.
If the thermostat isn't in the same box as the receptacle, I would suggest adding a note on the cover plate stating that it's "Thermostat Controlled" so the next homeowner won't be confused as to why it only sometimes works.
Old 06-24-22, 01:08 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, it will work as long as its a cooling thermostat.
Geo🇺🇸
CircuitBreaker voted this post useful.
Old 06-27-22, 09:07 AM
D
How to wire
How do you wire it? You said that it could be done. I need to know how.
Old 06-27-22, 10:01 PM
Received 3,415 Upvotes on 3,063 Posts
The thermostat has two wires. It just interrupts the black wire to the receptacle.
Will this be a portable set-up ?
There are several different styles of stats so if you post a picture we can help you with the set up.
How to insert pictures.
Old 06-28-22, 10:56 AM
D
Pictures of thermostat
I hope it will be permanent.
Does this look good?
Is the resistor good?
Old 06-28-22, 12:49 PM
Since that is it's own junction box you can mount that to the wall. You can run power thru it or use a two wire cable to connect to an existing receptacle. The grounds get attached to the metal box for safety. Not shown in diagram.
That device on the thermostat is a high heat safety fuse. In the event of a fire.... it will blow open permanently shutting off the fan.
The top diagram is power passing thru.
The bottom diagram is a two wire cable to the receptacle. It's recommended to tape or color the wire a different color from white so that it's not confused as a neutral. The open KO needs to be sealed.
