Hello! I have a light fixture in my bathroom that keeps flickering. Turns out there’s no lightbulbs, I’m not sure what kind this fixture is and how to stop it. Sometimes it’ll flicker for day, then doesn’t turn on at all for a month, then back to flickering. Help? Thank you!!
I'm not sure how old it is, maybe about 3 years? I recently rented it out.
Any advice on how to fix a loose connection or bad switch?
Thank you so much!!
I doubt its a bad switch or connection. The best to find out is conect a regualar incadescent bulb or use a VOM meter/.
LED ballast or electronics will in fact wear out over time. Not unusaul for a LED ceiling light to fail. I currently have screw in LED bulb that will turn on and off for about a minute before it warms up enough to stay on.
One way is to turn off the breaker for that circuit and re-do each connection. Focus on wire nuts. Usually you can pull or wiggle the wires & nut and if one is loose, redo the connection. If checking the switch back stab connections are a common problem point and it is more reliable to put the wire to the screw connection on the switch.
Or you can test. You will need a multi meter or voltage tester. When the light is not working check for power at the wires right at the fixture. If no power then go to the switch and check for power. Keep going upstream until you find power and check the connections. If the fixture does have power going to it and the light isn't working then replace the fixture.
I installed a Hunter 72 inch HFC-72 six blade ceiling fan in my garage late last year. Shortly after installation, it began making a loud, "out of round" growling noise when on high speed (this is a three speed fan). The fan is controled by a 3 speed Hunter wall switch installed by an electrician. I did all the normal troubleshooting (checking for interference, out of balance, loose screws, etc) before contacting Hunter support. They agreed something was not right with the fan and sent a replacement. I carefully installed the replacement and it ran really quiet until it I stopped using it when cooler weather arrived. Now that summer is here, I am using it every day and it is now making the same loud, "out of round" groeling noise when ran on high. When I put my finger on the bottom area of the fan shaft, I can feel the grinding/vibration that is in time with the noise. All the troubleshooting was done again and no cause was found. However, I did noticed that when I run the fan on high after it has sat overnight, it runs really quiet for about 20 minutes before making the noise again. I contacted Hunter support again and sent them a video so they can hear the noise (I would attach that video here, but apparently I can't send a video on here). Hunter is sending another replacement fan. I would feel a whole lot better getting this new fan if someone could tell me what is causing the noise. Please let me know what you think is going on. Also, if there is a way to attach the video, please let me know what that is.
Thanks advance!!
Hi all! I'm looking to install a 26 pound ceiling fan and am trying to figure out whether I need to have a new ceiling box installed. The construction is from the early 2000s and the existing j-box doesn't have any markings. Normally, I'd assume it needs to be replaced or reinforced. However, the ceilings are concrete and the j-box is firmly attached directly to the ceiling. Welcome any thoughts, and thank you in advance!
Ben
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220727_152740_6a85deae29e4e1daeffa6ba8b3754d9203208304.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220727_144927_7bcc1718b329b0407fc4235a04eee03e64fb6c52.jpg[/img]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220727_144938_8623e064cefb000213845729a345994b4b0d4e68.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x901/20220727_145244_77517bf28a4f48ac707b3d05a6c1df768ae96a64.jpg[/img]
