electrical issues
Old 07-30-22, 04:07 PM
H
Received 1 Upvote on 1 Post
electrical issues
Hi there seems to some electrical issues in my bathroom that started about a month ago. The light flashes on and off as shown in the gif below. Also about once a week the lights and outlets in the bathroom stop working until I reset the GFCI in one of the outlets in the room. Can you suggest what I should do? Thank you
Top Answer
07-31-22, 03:58 AM
beelzebob
beelzebob is offline
Received 306 Upvotes on 271 Posts
The on/off of the light does not appear random so there is something electronically causing it. Is there a dimmer in the light circuit? If so can you bypass it to test? The GFCI tripping indicates a wiring issue. With the bathroom breaker open, removed each switch, lamp socket and outlet and check the wire connections for being tight. Move any wire with a stab connection to a screw if available.
Old 07-31-22, 03:58 AM
B
hellog, Trying2Help voted this post useful.
Old 07-31-22, 04:31 AM
Tolyn Ironhand's Avatar
Received 892 Upvotes on 753 Posts
GFCIs typically don't trip on a wiring issue, they trip on a ground fault issue. If the GFCI is old I would start by replacing it. If the new one still trips I would disconnect whatever is connected on the load side of the GFCI and see if that clears the ground fault.
Old 07-31-22, 12:32 PM
H
There's no dimmer on the circuit but there is a fan. I unplugged the the items that were plugged into the gfci outlet and even after resetting the gfci the light still flashes.
Old 07-31-22, 02:03 PM
Received 4,046 Upvotes on 3,630 Posts
Is it an LED fixture ?.... if it is.... it's most likely defective.
Old 07-31-22, 02:39 PM
The GFCI has nothing to do with the light flashing. If it is an LED lamp or fixture it is likely defective.
hellog voted this post useful.
Old 07-31-22, 05:42 PM
H
Can you educate me on why sometimes the light stops working at all (not flashing, just zero light) and resetting the GFCI makes the light start working/flashing again? Thank you
Old 08-01-22, 02:28 PM
B
Hellog, if I am reading post 7 correctly, the flashing light stops working because the GFCI tripped.
Resetting the GFCI restores power ( including the light) until it detects another ground fault.
