There are so many companies producing fans that it almost impossible to identify a particular manufacturer.
I would remove the lens and measure it. Plastic or glass ?
Possible that metal frame around the glass unscrews.
Look on the back of the light fixture for ID. (use mirror)
Look around the motor unit.... many times there is a small ID tag hiding.
I have a large lighting showroom near me. I'll bring in what's left or the frame to match visually.
Yes.... Craftmade. You may be better off buying a new fan or replace the entire light kit.
Their support is minimal. You may have to contact them directly....Craftmade.
Thanks , the_tow_guy and pjmax. Appreciate the help and feedback. I was thinking the same line that I would need to replace the entire light kit. I see that Lowes sells this brand and will check what they have for light kits. If no luck there, I will contact customer service at Craftmade.
My recessed lighting (by Progress, more than 30 years old) started switching on and off every few minutes (tried with two different LED lamps). I took it apart and find no thermal sensor, so I don't know what could do this or how to fix it.
The last time I did landscape wiring no permit was required. I am replacing and extending some low voltage landscape lighting that is probably 30 years old. My plan is to bury the wiring a couple of inches deep along a walkway. Is there any code requirement for burying or protecting low voltage wires?
