Replacing a recessed can light with ceiling light fixture
Old 12-19-22, 04:13 AM
D
Currently have a recessed can light placed between joists that uses provided housing clips for stabilizing to dry wall and anchored to offset joist on one side with a long wood screw.
I want to replace the can with a center mount light fixture. I have a 6" open hole with no cross stud, junction box or mounting bracket. What is a good cross member mount, given there is no stud or existing junction box present?
Old 12-19-22, 04:33 AM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
You could use a telescoping fan mount or cut and replace the drywall across two joists which will allow you to install an old work box anywhere it's needed!
Gen voted this post useful.
