Attach a ceiling light cover over an existing light
Old 05-23-24, 02:35 PM
P
Hello:
I am trying to Attach a custom ceiling light cover over an existing light, but cannot find the piece to do. We have the converter to change the existing canned recessed light into a standard fixture but now we need to place on top fixture. The fixture is brass, see picture, with three holes , approximately 12” diameter. We could screw it directly into the ceiling with anchors, however if we have to change the light bulb regularly the anchors would eventually give way I believe. It there some kind of “runner” we can attach to the ceiling which accommodates screws come down from the ceiling which we can use to attach the fixture. 3 Pictures of brass fixture and 1 of the ceiling is attached.
regards - Mel
Old 05-23-24, 05:52 PM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
I will wait for the pictures.
Old 05-23-24, 07:24 PM
Received 4,105 Upvotes on 3,687 Posts
Pictures loaded.
You can use a plastic or metal expanding anchor.
The anchor body is set in the sheetrock and the screw is removable.
Many sizes at the home improvement stores.
metal expanding anchors
Old 05-24-24, 10:58 AM
P
Wouldn’t unscrewing it over and over (to change the light bulb) eventually wear out the anchor?
Old 05-24-24, 04:09 PM
Received 59 Upvotes on 51 Posts
Use a good quality LED bulb and you won't need to replace it for a long time.
Old 05-27-24, 06:46 AM
P
Thanks all!
