5.7L engin OMC
Old 08-01-02, 05:37 PM
imphil
Angry 5.7L engin OMC
When I take my boat out and apply 2500RPM it looses power and backfires. I have replaced the ignition points with an eletronic ignition and replaced cap and wireing and plugs and it still backfires and looses power. When I back off on the power it runs corectly? I have allso checked the timming 8 BTDC. What is causing this problem? It is a 1988 GMC 5.7L cobra outdrive on a 25 foot Rennel boat
Old 08-01-02, 08:05 PM
BoatMech's Avatar
It could be the carburettor is running lean in the secondary.
It also could be that the shift module is being activated by
the incompatible ignition system.
Did you read the part about not being compatible in the
instruction book? Many systems do not work with the
OMC cut out module.
scott
Old 08-02-02, 10:05 AM
imphil
Thanks Boatmech, I did a compression test tonight and I think I have major problems. cylinders 6&8 Have 15 PSI and 3&5 have 60 psi all the rest have 170 psi Does this sound like a head gasket or valves? If I need a new engin wear can I find one or have this one rebuild fast? I live in Valdez, Alaska.
Old 08-03-02, 07:30 PM
BoatMech's Avatar
poor ignition timing caused burnt valves.
just pull the heads and look at the pistons.
You will probably get by with just new intake
valves. Felpro makes a good gasket set.
scott
Trackbacks are On
Pingbacks are On
Refbacks are On
