Recommended Propeller
Sir Ug
Does anyone know the recommended Original equipment propeller for my boat. I have a 1989 17' SeaRay 160 with 100hp Mariner Outboard engine SN: 0C207542
The prop that came with the boat is PN: 48-32750-19. Is this the Original equipment propeller? I can not find this propeller anywhere.
It's hard to say which propeller your Sea Ray used. A search on that part number came up with no matches in the Mercury Data Base.
All I can tell from the number is that it was a 19 pitch. Diameter is anyones guess.
Do you already have this prop, or do you just have the number? If you have the prop, why do you need to replace it? If it's just banged up, they can be reconditioned forless than $100 at any good prop shop.
If you contact your local Mercury Dealer, they have a prop selection service where they will loan you different props to test out to see which one works best for your application.
