Boat floor dry rot
Old 03-10-03, 07:28 PM
fewalt's Avatar
Boat floor dry rot
My 1987 17.5' F&S has a very soft spot behind the driver's seat.
I'm sure it's dry rot and wondering if this is the path to go to fix it:
1) remove seats
2) remove carpet if possible
3) find out how the flooring is attached and try to remove.
4) replace flooring supprts by fiberglassing in the appropriate PT lumber.
5) replace flooring, then re-carpet
How does this sound??
fred
Old 03-11-03, 02:43 PM
BoatCop
1) remove seats
Definite first step. They should be screwed into the floor or stringer. You can get to the screws by removing the cushions.
It will be possible, but will probably be destroyrd in the process. Plan to replace it. Buy a good quality carpet, made for marine use. Stay away from ordinary indoor-outdoor junk from the hardware store.
The floors should be screwed into the stringers. There may be more than one sheet (probably plywood). Inspect them all, and replace the ones that are bad or questionable (You don't want to do it all over again in a year or 2)
The floorboards are usually just screwed into the stringers, and some furring along the sides. They probably won't be bad. Read belwo about glassing wood.
Use a good marine grade plywood. Some advocate glassing the floors to keep out moisture, but that usually just keeps water encapsulated and causes it to rot from within. A good coat of varnish will suffice.
Like a lot of work, but well worth it in the end.
Old 03-11-03, 06:34 PM
fewalt's Avatar
Hey Alan,
Thanks a bunch, that's about what I figured the process to be.
And, hopefully the flooring is just screwed down.
You mentioned marine ply. Is PT plywwod a good substitute?
I knew to order carpet from Cabella's or Overtons, etc.
Thx again, it will be a fun project.
fred
Old 03-15-03, 10:49 AM
Ed Imeduc's Avatar
Boat Stuff
You might want to check out "Defender 800-435-7180 for the STUFF you need here for the boat ED
