starting engine
baracudda's Avatar
04-12-03, 08:27 AM   #1
baracudda
starting engine
starting boat for season......wont start......i have a new battery, distributor cap, rotor, plugs and i cleaned all the wires....i dont any spark...... what can it be....................
BoatCop's Avatar
04-12-03, 03:41 PM   #2
BoatCop
You didn't mention if you installed new points, and whether the point gap/dwell was properly set.
Could also be a condenser, coil or ballast resistor.
Once all those have been checked, be sure the plug wires are routed correctly (It does happen.), and set proper timing.
