125 force engine
wade1's Avatar
04-17-03, 11:18 PM   #1
125 force engine
I have a 125 force or "mercury " outboard engine.
Is there a automotive type replacement spark plug for this engine instead of the boat type, I don't have a boat dealer very close to me. thanks
BoatCop's Avatar
04-19-03, 08:03 PM   #2
BoatCop
Spark plugs for outboards vary considerably between years. Call a Mercury shop and give them the year and serial number of the engine, and ask what spark plug it uses.
If you still have the owner's manual for the engine, that should have the plug number, too. Many different manufacturers make similar plugs, and can cross reference to whatever specific plug you need.
Most use NGK or Champion, and once you have the number, your FLAPS (Friendly Local Auto Parts Store) should be able to get them for you.
They'll also be about 1/2 the price of what most Merc Shops would charge. My new 225 Mercury Optimax plugs cost $24.86 each at the Merc PLace, but NAPA had the identical plug for $10.85. (Yes. That's in US dollars and priced EACH! )
BoatCop's Avatar
04-19-03, 08:07 PM   #3
BoatCop
One more thing. If you still have problems finding them, you can order them direct from Mercury at:
www.mercurypartsexpress.com
You'll need your engine serial number, found on the bracket that mounts to the transom.
wade1's Avatar
04-19-03, 09:05 PM   #4
thanks alot. I appreciate it.
johjack's Avatar
09-13-05, 12:49 PM   #5
johjack
Force 125 Outbaord Motor Question
I have a Force 125 outboard. The engine is getting fuel and is turning over fine....I leaned the spark plugs and they are wet after cranking.....Engine will not fire at all.....
Is there an electrical part that controls the firing of plugs that I can replace?
Thanks!!
Savannah Dan's Avatar
10-07-05, 01:45 PM   #6
What year and model number is your Force? The info should be on a data plate on the transom bracket. I can tell you what plug you need if you get me those numbers.
The Force O/Bs have a weak ignition system, and parts are getting harder to get. Are any of the cylinders firing? If none are firing, the problem is probably under the flywheel. Something that can mimic a bad ignition system is a weak starter. It the starter does not spin the engine fast enough, it will not fire. Happened to me last year.
