Boat side molding repair
Old 06-27-03, 06:29 AM
Bob Maryon
Question Boat side molding repair
How do I keep rubber edge molding from coming off the sides of my ski boat ?:confused
Old 06-27-03, 08:24 PM
BoatCop
What type of molding is it? Is it the rubber strip that runs through a metal channel, or some other style? What year and make of Ski-boat?
A little more info (and possibly a picture posted somewhere) will help us figure out your problem.
Old 07-02-03, 06:25 AM
Bob Maryon
Yes it is rubber molding running inside metal channel It is a 1993 sanger Dx20 Tournament ski boat Thank you Bob
Old 07-08-03, 05:29 AM
Bob Maryon
Old 07-12-03, 07:15 AM
BoatMech's Avatar
If the moulding is popping out from water pressure underway
you can replace the rubber strip. take a sample to the
boat shop and have them order you the proper length.
I have had some success with clear silicone. Reinstall
the existing stip using rtv silicone sparingly, it works
as a lubricant to get it back in and seals it in place.
If it is coming off when you are docking and getting off
and on the trailer, be more careful. Its going to do that
if you are rough with it
Scott
Old 07-14-03, 09:32 AM
Bob Maryon
Scott
Old 07-14-03, 09:35 AM
Bob Maryon
Thank You Very Much! I Will Use Your Suggestions
Bob
