Got my carb back on.
Old 07-29-03, 07:08 PM
bryan77
Ok folks finally got my carb rebuilt(actually only tookl about 5hrs total, disassemble, clean, soak, dry, and rebuild, and reinstall. wasnt bad at all. Started right up I did a little tinkering and the Air/fuel mixture screw. have the motor running in a trash can filled with water. I plan on taking it to the boat ramp tommorow, where I can take a quick spin, return to the dock , and readjust........ so hopefully tommorow I will get it fine tuned. I noticed at higher rpm it smoked more then I am used to,maybe its just beceause I am not moving? Could this be a lean mixture, or something else.
Old 07-30-03, 10:13 AM
bryan77
I took it to the ramp today, started right up. I was impressed it has never started that easy since I bought it 3 yrs ago
Took it for a little spin, the manual said to run it hard for 1or 2 minutes take the plug out and look, which I did and the plug(insulater) was really white, and very dry, I was worried about it running to hot, Did a little adjusting put the plug back in and ran it again, this time the plug was a tannish color which the manual says is good, and it was a little wet. Ever since I have owned this boat, I could never go from full throttle to neutral really fast without it stalling. Now I can do it all day long...................I may do a little more tweaking as needed, but I was suprised at how easy it was................ Thanks for all the help. Hey Boatmech, have you got a part # for that tach, Were going tubing in less than 2 weeks so If I could I would like to get that in. Again thanks for the help everyone.
