Trailer Wheel Bearings
I just replace the wheel bearings and race ways on my trailer. I have not been able to find the proper torque to tighten the nut. I know on some autos you tighten to foot pounds specified and then back off a little. The axle is tapered, 1-3/8" inner 1-1/16" outer in case size make a difference. Thanks.
Lanny
Lanny
Lanny,
What works for me is to first pack the bearings with grease.
Then assemble the wheel and while spinning the wheel by hand tighten the bearing nut untill you feel a moderate amount of resistance.
Then back off the nut untill the wheel just begins to spin free.
Smear a bit of grease into the end cap, make sure there is no side play and close it up.
You should check for play after a driving a few miles.
Opps! DON'T FORGET THE COTTER PIN.
Received 1 Upvote
1 Post
Like GregH here. After its snug back off the castle nut one hole for the cotter pin. Also if this is for a boat Id use a Bearing Life or a Buddy wheel bearing protectors they will help keep out the water in the wheels there.
ED
ED
