clicking sound (starting)
William521's Avatar
07-16-04, 07:06 PM   #1
William521
Hello, I have a boat that just doesn't want to start. What basically happens when I turn the ignition to the start position is that I here a constantly clicking sound. Sometimes the drive assemly will turn alittle bite and then stop and then the constanly clicking sound will start but usually I just hear that annoying constant clicking sound. I believe that that constant sound has to do with the solenoid switch constantly switching on and off but don't know for sure. I think I need a new solenoid switch. What do you pros think about this and what this could be. Thanks alot for the help. I appreciate this alot .
kpg712's Avatar
NY
07-17-04, 02:47 AM   #2
1. check batt. connections
2. test batt.
3. bad starter?
William521's Avatar
07-17-04, 10:01 AM   #3
William521
Thanks for the reply. That procedure seems simply enough. I supposs I will just replace the starter sense I have already done those other 2 things Thanks again. Will
Ed Imeduc's Avatar
MO
07-17-04, 02:25 PM   #4
Make sure that the battery is good and full charge. See if you cant get a rebuilt starter for it.
ED
