Bottom paint remover
Nik-c's Avatar
09-07-04, 09:00 PM   #1
Nik-c
I have a 23 foot SeaRay with old, partially chipping bottom paint that I'd like to remove (not replace). What's the best way to remove bottom paint without sanding?
Here's a pic of the current bottom paint:
http://www.haleakala.us/bottompaint.jpg
Ed Imeduc's Avatar
MO
09-08-04, 10:26 AM   #2
A 3800 psi pressure washer works . Dont get to close to it
ED
Nik-c's Avatar
09-08-04, 02:56 PM   #3
Nik-c
Would it do anything to the finish?
Some of the bottom paint is pretty well dissolved in, but the rest like I said is almost flaking off.
I just don't want to hurt the finish under the bottom paint. Should I reapply anything after removing the bottom paint?
Ed Imeduc's Avatar
MO
09-08-04, 04:00 PM   #4
Might go to http://www.defender.com
Id think put a white Awlgrip on it after you have it clean. Are they have many interlux paints that you can use.
ED
Nik-c's Avatar
09-11-04, 09:14 PM   #5
Nik-c
OK, I used a 3500 psi pressure washer and here are my results:
http://www.haleakala.us/powerwash.jpg
http://www.haleakala.us/powerwash2.jpg
The remaining paint seems pretty stuck on there. Any suggestions on removing the leftovers?
Ed Imeduc's Avatar
MO
09-12-04, 02:13 PM   #6
I just sand a little so its flat and go for awlgrip or you can go for a full Gelkote white on it.
ED
Nik-c's Avatar
09-12-04, 04:39 PM   #7
Nik-c
Thanks a lot, Ed. Appreciate the help.
