white foam in carb
amazed_12001's Avatar
01-04-05, 09:56 AM   #1
amazed_12001
white foam in carb
3.0 mercruiser IO white foam water oil mix in carb but no sign of water in oil. What gives?
joaa's Avatar
IA
01-05-05, 05:22 AM   #2
its in the carb so whats in the gas tank?
01-06-05, 08:47 AM   #3
amazed_12001
just gas the white foam is oil and water mix
joaa's Avatar
IA
01-06-05, 02:43 PM   #4
not sure about yours but on most car engines theres a breather tube from the valve cover(pcv vent line) these sometimes put oily foam into the air cleaners.
If theres a positive crankcase ventilation (pcv) valve somewhere change it and see what happens
