79 mercury 140 ob no spark #1 and#5 cyl
Old 04-20-05, 02:52 AM
T
tsilva
tried changing plug,wires,coils help!
Old 08-23-05, 04:11 PM
snyderhouse2
If you're only missing the spark to 2 of the cylinders, the problem would have to be the distributor cap, since you've already replaced everything else (plugs, wires, coil). I had a problem with no spark to any of my cylinders and the problem was the points.
Old 08-23-05, 07:32 PM
P
Do you have a distributor or distributorless ignition system? I believe 1979 had distributorless ignition. Correct me if I am wrong.
Old 08-31-05, 07:34 AM
T
txtaz
Nope, no distributor there. Check your power packs.
