water pump replacement..'96 johnson 115hp
Old 05-10-05, 04:05 PM
BL83
Question water pump replacement..'96 johnson 115hp
When changing the water pump.....if I am looking at it correctly you have to disconnect the shift linkage in the lower unit.....How do I go about detaching it in order to drop the lower unit....or is there an easier way??
Old 05-11-05, 01:34 PM
Ed Imeduc's Avatar
Some times on the side of the houseing there is a small cover plate if you open that up you reach in and disconect the shift rod. If the pump also has a wear plate there put a new one in with the impeller.
ED
