First Timer
Dsherm112's Avatar
PA
05-18-05, 09:39 AM   #1
First Timer
I'm going to take the boat out for the first time this weekend. The previous owner showed me the basics, but I have a question regarding the gas can. The gas line has a squeeze ball in the line. After the line is attached to the engine do I squeeze this several times to prime the engine? If so, how many times?
Please explain the complete procedure.
Thanks.
Sherm
oldJoe's Avatar
05-18-05, 03:28 PM   #2
Priming
There should be an arrow on the bulb.
This indicates the direction of flow of the fuel, ie from the gas supply to the engine. The bulb is a little pump that moves the fuel to the carb. There I believe fuel fills the carbuerator bowl, when that is done no more fuel can enter; so the bulb therefore becomes hard and that is where you stop.
From that point you startup procedure is to use choke to get a rich fuel mix down the carb throat for initial (cold) starting.
Important point to remember is NO fuel spills in a boat.
Perhaps other readers can suggest other fuel safety concerns here.
Ed Imeduc's Avatar
MO
05-18-05, 03:40 PM   #3
Its all like said . Put the line on the motor pump the bulb till its firm and a little choke then turn the motor over. If to much choke you can flood the motor Fill all gas cans on the dock not in the boat.
""""First dont forget the transom plug for sure""""
ED
Dsherm112's Avatar
PA
05-18-05, 04:34 PM   #4
Thank you!
Sherm
