nothing happens! [engine starting problem]
doingitright27's Avatar
05-24-05, 05:12 PM   #1
doingitright27
I have an 1990 OMC cobra 350 that is having touble starting. I have replaced the starter relay, solenoid, 50A fuse, and have the same problem. I have a full battery. When I turn the key to the acc position all the dash gauges come on, the turn it to start and I get nothing, not a whine nothing to the starter or the solenoid. Where do I start looking now?
WalleyeHunter's Avatar
05-31-05, 08:34 PM   #2
WalleyeHunter
Check continuity of the wiring harness from the ignition switch to the starter and solenoid. Then then test the ignition switch in each position and also check for leakage of the switch. (you need a ohmmeter or megger)
