Engine installation
Old 06-04-05, 05:17 PM
rickf1985
Unhappy Engine installation
Help, I am putting my engine back in and I can not get it to line up. I have the alignment tool and that is what I can't get lined up. If I use the old fiber washers without the spring and lower the front mounts all the way I can get it to work. If I use the new fiber washers and put the spring inside the washer as called for in the book the rear od the engine is to high. If I raise the front mounte up then the angle is way off. Any idea's on what I am doing wrong? Thanks in advance.
Rick
P.S. I forgot to put the boat specs. in, it has been a long day.
1988 Baja, 7.4 330 horse Bravo one outdrive.
Old 06-07-05, 07:35 PM
Hi Rick I see no one had an answer for you and unfortunately I don't have the answer ether.You might want to try this forum WWW.boatered.com Good Luck. MIKE
Old 06-08-05, 05:40 PM
rickf1985
Rick
Thanks Mike, I actually found the answer I needed on Iboats.com. Very helpful site.
Rick
Trackbacks are On
Pingbacks are On
Refbacks are On
