'71 85hp johnson with hydro-electric shifter
Old 10-25-00, 06:35 PM
Question
Lower unit will not go into neutral or reverse. I have bought and replaced the two selenoids in the lower unit. What else could be wrong??????
Old 10-26-00, 11:03 PM
Smile
The most common problem is lack of pump pressure. And putting the wrong fluid in the unit.
Did you happen to notice the condition of the pump in the nose of the gearcase.
The drive pin on it may be sheared too.
Are you getting full travel from the cables?
Thats a pretty tricky housing to work on.
But a good unit, get back to us on what you found.. thanks Scott
Trackbacks are On
Pingbacks are On
Refbacks are On
