85 century no RPM's
Old 06-17-05, 10:18 PM
B
bige34
85 century no RPM's
Help!!!
I have a 1985 Century Mirada 25' I/O. The engine sounds absolutely great but the problem is I can not get the RPM's to go over 3200 therefore I can't get up on a plane. I have changed the prop to a 19 pitch, re-built the carb, changed the cap, rotor and wires, and adjusted the timing all to no avail. I have an alpha 2 outdrive and the engine is a 350 v8. Any ideas??? I'm stumped.
Thanks for any help
ERIC JOHANSEN
Old 06-18-05, 11:59 AM
O
Low rpm
I think the engine is aged.
Check compression : compression = hp.
Might idle poorly at low idle as well.
Old 06-18-05, 12:01 PM
O
Cannot obtain high rpm
