Ignition Problem. Please Help!
sparson's Avatar
06-20-05, 10:35 AM   #1
sparson
I can start my boat with the ignition key but i cannot turn the motor off. What could be the problem. The starter is going to be starting a 40hp two stroke outboard motor.
papasmurf's Avatar
06-20-05, 02:36 PM   #2
Probably the ignition switch itself. What year and HP?
sparson's Avatar
06-21-05, 04:29 AM   #3
sparson
year of boat and motor
The year of motor and boat is 1987.
papasmurf's Avatar
06-22-05, 07:48 PM   #4
If you can get to the switch, check for continuity between the two "M" terminals on the back of the switch. With key in run position, no continuity. Key in off position, continuity.
