95 seadoo speedster no spark at all
Old 07-01-05, 06:21 PM
holotoftrouble
need help here,i have a 95 speedster and i have no spark at all,the plugs are from bombardier and gaped good,i changed the cdi,i changed the starter,all the grounds are good,i checked the cut off switch and key switch and everything is good,and also the fuses and starter silinoid and all is good so any help would be apreciated,tks man!
Old 07-03-05, 09:47 AM
I am not very familiar with PWC's but have worked on many bombardier engines. That being said. If you know your CDI and wiring are good I would check the ignition coil. Good luck. MIKE
Old 07-03-05, 06:45 PM
holotoftrouble
my seadoo
tks for getting back to me dude,the cdi is good and the wiring is good and i'm even sure the ignition coil is good, my buddy tested it......the engine turns but there's just no spark,if the coils was toast,the engine wouldn't turn,would it???maybe there's a better way to test the ignition coil,please let me know!
thanks again dude.............the thing is when i was driving the boat along at full throttle,then i decided to slow down so when i put the throttle down it just stalled and then no spark fron then on..
Old 07-03-05, 07:20 PM
holotoftrouble
my seadoo
just one more thing,you told me i should check the ingnition coil but i think thats what i call cdi????
Old 07-04-05, 09:07 AM
williamr
simillar?
I dont know if they are similar at all, but my dad and i wee getting no spark on our out board motor. we replaced the ignition switch and a coil, turns out the key on the fly wheel was sheared, when we replaced that it fired right up. after spending $60 replacing good parts it was a 26cent part that did the trick. Good luck!
Old 07-04-05, 04:24 PM
Speedster
Search Seadoo forums at www.jetboating.net
Old 07-05-05, 08:51 AM
holotoftrouble
my seadoo
tks for the help guys,i found the problem.....it was the dam starter relay,i didn't think that it would cause no spark at all,but thats cool im back on the water........wooooooohooooooo!
