KAwasaki Waverunner
KAWASAKI Waverunner Stalls after 15 mins
I am not sure if this is the right forum for a Jetski.... I have a 1994 Jet ski that ran great last year but this Summer has not ran over 15 min's each time out. Once out on the Ocean it has alot of Power.....after 15 or 20 min's it loses power and will not go..you can coast at slow speed but when you try to get up speed it will boggle down.... Any ideas? It has a new battery and new plugs , new oil and gas... ....The winter months are too long to enjoy in NY!!
Also can anyone tell me if there is a solution to having to jump in the water and pull seaweed out from underneath ??? I don't see anyone else constantly jumping off to do this and was wondering if it was just the Kawasakis that need this done.
I highly doubt its anything electrical.
Did you use the right kind of oil ? same that was in it before. I wonder if the oil mixture is working right, i cant recall if those were 2 cycle engine or 4 stroke.
The pump runs from the back of the boat, propeller inlet area, should be able to find it.
IS it smoking from the time you start it up or after been running 10-15 minutes ?
sounds then like a mixture mix, some of those 2 cycle oils, if you look on the bottle are not always a 50/50 mix, some brands have a different mix ratio.
If I can give one tip, its to stay away from pennzoil 2 cycle oil.
I live off a river, I have owned a few boats and worked at a motorcycle shop, that also repaired watercraft. I have more engines going buy buy due to that oil.
I prefer quicksilver and johnson 2 cycle oil.
Let us know if it turns out to just be the mixture.
sporty
sporty
